Sway Bar End Links - 99 camaro ss
Old 10-13-2013, 07:38 PM
Wheelie King's Avatar
Default Sway Bar End Links - 99 camaro ss
What is the correct sleeve size or part number for the energy suspension front sway bar end link for a 99 camaro ss? Websites are refering me to energy suspension 9.8118r I measured and the sleeve size looks a little big. Does anyone know for sure?
Old 10-14-2013, 12:46 AM
99Bluz28's Avatar
Yes, that's the correct pt# if you want red bushings, if you want the black bushings then you want 9.8118G .
I'd suggest checking your local auto parts store, since most that carry ES parts normally have ES end link kits available.
BYW, if you want some ES end links 1/4" shorter then get pt# 9.8117
Old 10-15-2013, 08:03 AM
UMI Performance's Avatar
You can always trim the sleeve too to make them shorter. Just can't make them longer.
Quick Reply: Sway Bar End Links - 99 camaro ss
