UMI Performance Suspension Over Haul - 1999 SS - Lots of pics!
Old 11-04-2013, 09:23 PM
SparkyJJO's Avatar
OK I just have to ask... you're going through all this and then putting on poly LCAs why?
Unless it is getting set up as primarily a drag car, then I could see why.
Old 11-06-2013, 03:16 PM
1994_383_Z28's Avatar
It's a beautiful site seeing all those new suspension pieces together like that
Old 11-06-2013, 06:21 PM
scj
scj's Avatar
Originally Posted by Zark
Talk about great benefits, screw dental and 401k, I want free suspension rebuilds! subscribed
The even better thing is he probably has 401k, and insurance. Lols. It's a tough job, but someone's gotta do it.
Old 11-08-2013, 11:59 AM
UMI Performance's Avatar
Old k-member and front suspension coming out. Also a few comparison pictures of factory vs. UMI.
Old 11-09-2013, 08:14 PM
Homeless2bNY's Avatar
i remember doing the same job to my 02 SS.
nite and ******* day with the UMI stuff.
but i had QA1 shocks, not shiny pretty blue ones. lol
those Afcos look like they will get the job done.
give me feed back have you put some hard miles on them.
i might had to upgade my set up to keep up Ramey. HA!
Old 11-11-2013, 09:12 AM
The UMI front suspension pieces and AFCO shocks are starting to go in.
Quick tip when using adjustable coil overs- Always apply a heavy amount of anti-seize to the threads. This will prevent damage to the shock body and adjuster when changing heights.
Old 11-13-2013, 09:12 AM
A-arms are going in and front suspension being being put together.
This picture does a great job of showing the travel our Roto-Joint offers and especially in important pivot areas like the vertical front a-arm busing. Placing a polyurethane busing or other non-pivot bushing in this location would cause a serious binding issue.
Old 11-16-2013, 07:13 PM
fasteddy's Avatar
Looks good!
What kind of mount is that on the top of the shock?
Does that bolt in or weld in to the upper section of the a-arm assembly?
Old 11-17-2013, 09:54 AM
97FormulaWS-6's Avatar
Location: Land of the Mormon's although I'm not one of them
Originally Posted by fasteddy
Looks good!
I'd like to know this as well!
Old 11-19-2013, 07:39 PM
Rare96LT1Formula's Avatar
Did you guys recently start stocking AFCO? I don't see them on the website and am interested in getting some pricing.
Old 11-20-2013, 07:44 AM
Hello,
We are distributor for AFCO and have been for a long time, but haven't had the items listed on our site yet. If you are interested in pricing or any items please call Ramey at 814-343-6315 or by e-mail- ramey@umiperformance.com.
The AFCO front coil overs for the 4th gen use a bearing mount on top and bottom and a standard 2-1/2" spring. They eliminate the front upper rubber shock shock mount.
I hope this helps,
Ryan
Old 11-20-2013, 09:04 AM
  #32
UMI Sales's Avatar
The Afco's are pretty cool in that we can achieve any valving you'd ever want. Our engineering contacts there provide all the dyno charts and can help us tune, or even re-valve most of the models. This type of thing isn't necessary for everyone but can be beneficial for shootout guys looking for that perfect setup.
Like Ryan said, the 2-1/2" springs really open up the balance options as well.
Winter got here too quickly. I'll be begging Jerry to borrow this car in the spring. I hope he has the nitrous topped off.
Old 11-20-2013, 08:46 PM
  #33
nascarnate326's Avatar
How do you support the motor if the k member is out?
what do you expect the weight difference to be?
Old 11-20-2013, 08:51 PM
  #34
LetsRide's Avatar
I'm glad you asked this. I was wondering how the engine stayed in there. I could only come up with the idea of jacks and a tranny mount/stand.
Old 11-20-2013, 08:53 PM
  #35
02 reaper z28's Avatar
nice over hall
Old 11-20-2013, 09:45 PM
  #36
LilJayV10's Avatar
Yup. In the first pic when they are dropping the stock K member out there's a tall jack stand under the engine.
Old 11-20-2013, 10:10 PM
  #37
UMI Sales's Avatar
We use some transmission jacks on occasion but the real trick is hanging the engine from the strut tower brace with nylon straps. Or if you don't have a STB, you can put something across there to hold it from above.
We expect our k-member to save approx 25 lbs, depending on what engine mounts are in there.
ramey
Old 11-22-2013, 05:45 AM
  #38
Perhaps this shows my inner hick but your basically taking straps and wrapping them from the header to the strut tower brace and that safely holds the motor?
I am thinking about doing a very similar "build" but do not have access to a lift, and don't want to take the motor/trans out.
Old 11-22-2013, 07:38 AM
  #39
LilJayV10's Avatar
The "correct" way is to use something similar to this engine support bar. There are several different kinds.. I'll be damned if I'm working under an engine support by a freakin ratchet strap.
http://www.otctools.com/sites/defaul...?itok=4hUHCHAP
Old 11-25-2013, 07:20 AM
  #40
Few pictures of the rear suspension items bolting in. Starting with the rear control arm relocation brackets.
Quick Reply: UMI Performance Suspension Over Haul - 1999 SS - Lots of pics!
