What Poly Trans Mount To Run With A UMI Torque arm Relocation Bracket?
Old 10-31-2013, 05:23 PM
Sinister_Z28's Avatar
Default What Poly Trans Mount To Run With A UMI Torque arm Relocation Bracket?
Hey all i just ordered some new stuff from UMI and was wondering what poly trans mount to run with my new UMI Torque Arm Relocation Bracket? I looked at some that summit sells but they all look like pretty much the same thing. Any info or part numbers and vendors would great. Thanks.
Old 10-31-2013, 10:47 PM
99Bluz28's Avatar
You actually really don't need a poly trans mount. The factory rubber mount is more than enough with the TA off the tail of the transmission, but if you're going to get a poly mount Go with the Prothane mount (#7-1604-BL).
Old 11-01-2013, 09:35 AM
Thanks for the suggestion. Im going with solid motor mounts and umi recommends a poly trans mount with there relocation bracket.
Old 11-01-2013, 09:39 AM
It's not mine! woo hoo!
demonspeed's Avatar
Another vote for the Prothane. Check it out here: http://www.ws6project.com/user_stor/...mission-mount/
Old 11-01-2013, 11:25 PM
Thanks for the info. Just a quick question i see that there are different styles of poly mounts such as short versions and regular length versions, are the shorter versions for different style trans cross members?
Old 11-02-2013, 04:57 AM
trans_am7935's Avatar
Although they may recommend it, i went back to a rubber factory mount after getting vibration though my shifter with a poly mount.
Old 11-02-2013, 05:40 AM
The Scammer Hammer
dr_whigham's Avatar
Go with the prothane. The energy suspension has a load plate and other crap, and that's the one that gets the most complaints. I absolutely LOVED my solid motor mounts and prothane Trans mount.
Old 11-02-2013, 08:49 AM
UMI Performance's Avatar
Quick warning: with the relocation kit a poly transmission mount will add increase vibrations. If you are noise/vibration sensitive I recommend rubber as well.
Old 11-02-2013, 09:36 AM
Thanks for all the suggestions and recommendations guys.
Now when u say added vibrations how much worse than stock would a poly trans mount make? Keep in mind the car has a 408 in it and I'm frankly getting tired of my trans shifting toward the passenger side at WOT. I don't consider myself vibration sensitive but I'm curious to know how much added vibration it'll have. Oh forgot to mention the car also has tsp true duals on it.
Old 11-02-2013, 09:41 AM
You probably won't notice it or mind it based on your build. We have a lot of bone stock cars installing relocation kits and poly trans mounts then complaining to use about increased vibrations. Sometimes we can't win so I try to be proactive
Old 11-02-2013, 10:03 AM
01ssreda4's Avatar
Stay rubber!!!
Old 11-02-2013, 10:59 AM
The Scammer Hammer
dr_whigham's Avatar
I had the UMI relocation kit with their DA TA. (Awesome parts) When I had the stock crossmember I felt it more. When I swapped to the UMI, the "vibe" wasn't quite as much. It just feels more solid.
OP, seriously, go with a Prothane and don't look back.
Old 11-02-2013, 11:05 AM
jsteele90's Avatar
go with a GM factory mount.
Old 11-02-2013, 12:35 PM
Just out of curiosity why is everyone saying go with a rubber mount over a poly? I learned when i started this project that when u have a modded car u have to give up some luxuries to feed ur desire for speed
Thanks for the warning UMI i greatly appreciate ur guys feed back and opinions. U guys are awesome and u guys will get my call when i have the coin for more suspension parts.
Old 11-02-2013, 07:09 PM
demonspeed's Avatar
Bolded the statement that matters. These aren't luxury cars.
For instance, some people whine about poly motor mounts. I noticed absolutely NO difference between the OE rubber mounts and the Prothane poly mounts. I expect the same experience with the poly trans mount.
Further, it's such an inexpensive part, just go with poly and sell it if you don't like it.
Quick Reply: What Poly Trans Mount To Run With A UMI Torque arm Relocation Bracket?
