New!!! 1993-2002 F-Body to C5 & C6 Billet Brake Conversion Brackets
Old 11-21-2013, 12:49 PM
Founders Performance's Avatar
Default New!!! 1993-2002 F-Body to C5 & C6 Billet Brake Conversion Brackets
C5 & C6 Brake Conversion Brackets
Made In The USA!
Formerly known as "Bob Bishop's Brake Brackets" and now known as F-Body "TrackBrackets", these brackets adapt the complete Corvette which includes C5, C5 Z06, C6, C6 Z51, or C6 Z06 front brake system to any 1993-2002 GM F-Body. The brackets are CNC machined from a solid billet of 6061 aluminum in a T-6511 temper/post treatment and are then hard anodized. The kit includes the left and right hand adapter brackets, all necessary non-factory mounting hardware, and complete step by step installation instructions and a list of necessary tools The brackets went through destructive testing with an independent laboratory to determine real world strength. The brackets sustained a load of 22,900 lbs. on a brake dyno and still did not fail. That is the weight of more than 6 complete F-Body automobiles on one bracket. Most competing brackets are .375" thick (some are even thinner), whereas our bracket is .600" thick. Each bracket weighs only two pounds.
Features Unique To These Brackets:
  • Material was selected with the engineering advice of one of the leading Kaiser Aluminum metallurgist and a couple aerospace engineers. 6061-T6511 was selected due to its ability to NOT loose its strength during heat cycles like 2024 or 7075 grade aluminum.
  • Load Fixture Tested to an actual load 22,900 lbs. Actual maximum calculated brake force on a full weight car with race tires and max deceleration is about 3,800 lbs. This gives a 6 times safety margin from maximum possible load.
  • Hard Anodized for a quality finish which penetrates into the aluminum for better corrosion and scratch resistance. We did not powder coat due to the heat generated by the powder coat process which weakens aluminum especially the higher strength aluminum such as 2024 and 7075. The other problem with powder coat on this application is the bolts will break the surface of the powder coat and allow moisture to corrode the aluminum; hard anodizing will not allow that to happen.
  • Critical hardware is grade 12.9 perma-plated with UNJ rolled threads not standard UNF threads for a stronger bolt compared to other designs
  • Properly machined to reduce or eliminate the brake pad taper commonly found in other brackets.
  • Not one size fits all but a left and right hand bracket to give extra strength and stability in the required areas.
  • Generous CNC machined radius’s and edge breaks to eliminate any and all stress risers
Attached Thumbnails New!!! 1993-2002 F-Body to C5 & C6 Billet Brake Conversion Brackets-c5-brake-bracket-600.jpg
Old 11-21-2013, 06:45 PM
Rare96LT1Formula's Avatar
Another nice piece from Founders at a fraction of the competitions price. Any plans on carrying rotors/calipers/pads?
Any updates on the torque arm relocation bracket?
Old 11-22-2013, 05:51 PM
Sorry but we don't have any updates on the relocation kits. If you need one now I would look at the BMR ones.
Old 11-23-2013, 12:40 AM
The Guz's Avatar
These look real nice. Do these require cutting like the other kits?
Old 11-23-2013, 05:46 AM
Driver_10's Avatar
Those are REALLY nice...Good quality work, I'm impressed.
Hey... heres a weird one for ya.
Do make c5/c6 rear conversion brackets for the 92+ C4 vette?
Old 11-23-2013, 10:30 AM
badformulaLS1's Avatar
Your prices are unreal! Please keep em low, planning to do a little Founders suspension build after the new year. Getting the LCAs, panhard bar, strut tower brace, and subframe connectors. Might even consider this brake conversion kit while I'm at it. Along with BMR springs and the Koni STR.Ts. Can't wait!
Old 11-23-2013, 10:31 AM
badhombre's Avatar
erm... you guys do now BMR has had these for years for $160 right?
Old 11-23-2013, 11:05 AM
I haven't seen them that cheap ever... Theres even a guy selling a USED conversion kit for like 400 bucks here in the classifieds. Just looked at the BMR ones. Apparently a lot of people don't know about them if others are selling for 400+ new or used.
Old 11-23-2013, 04:14 PM
99Bluz28's Avatar
So what are the bmr one made from; aluminum or steel?
The reason for asking is that the BMR brackets look quite a bit thinner than the Founders.
Old 11-24-2013, 03:23 AM
01ssreda4's Avatar
Nice looking pieces. These may be in my future.....
Old 11-24-2013, 11:46 AM
badhombre's Avatar
They are on the website, and have been the same price since they came out. I guess people just don't know about them, maybe I need to get the word out haha.
They are made of steel, also
Old 11-24-2013, 12:48 PM
SparkyJJO's Avatar
That's nice and all, but please don't hijack another vendor's thread about it. Thanks.
Old 11-24-2013, 06:26 PM
badhombre's Avatar
I'm sorry, I didn't know I couldn't post on my PERSONAL account correcting a fact that seems to have been overlooked on a product, that is easily found by anyone.
Old 11-24-2013, 08:51 PM
Copy & Paste Moderator
VIP1's Avatar
Also, look at Founder's site, these are $153 so they are still cheaper than BMR.
Old 11-25-2013, 11:28 AM
SparkyJJO's Avatar
I'm not saying you can't (especially since I'm not a mod) but it is rather rude to advertise one vendor's stuff in another vendor's thread.
Old 11-25-2013, 12:08 PM
Yes you will need to cut the spindle for these to work.
Old 11-25-2013, 12:09 PM
No we only make them for the 4th gen. cars.
Old 11-25-2013, 05:07 PM
FASTFATBOY's Avatar
These are the old "Track Brackets" and these are THE ones you want on your car, period.
I have these on my car and it gets put on road courses on a regular basis.
Nice price BTW.
Old 11-26-2013, 11:07 AM
SPRAYED 01's Avatar
Can you explain what exactly is involved in cutting the spindle? Can we use the f body calipers?
Old 11-29-2013, 09:08 PM
Can anyone point me in the right direction to getting some drilled and slotted rotors, along with upgraded calipers for this setup?
Quick Reply: New!!! 1993-2002 F-Body to C5 & C6 Billet Brake Conversion Brackets
