Energy suspension trans mount
Old 12-02-2013, 08:13 PM
grim_ls1's Avatar
Default Energy suspension trans mount
Hi, I'm looking at transmission mounts and I see that energy suspension offers 2 different mounts. One being pn: 3.1158 and it says its a softer poly and lowers the trans to correct pinion angle. The other being pn: 3.1142 and it says it lowers the trans 1/4 of an inch for optimum pinion angle. I was wondering if anyone has had experience with either. Thank you in advance.
Old 12-02-2013, 10:10 PM
jsteele90's Avatar
i would go with a OEM GM rubber mount.
Old 12-02-2013, 10:44 PM
grim_ls1's Avatar
Its a secret Santa present for my brother and he doesn't care too much about vibration. He wants all energy suspension bushings.
Old 12-02-2013, 10:57 PM
jsteele90's Avatar
http://www.ws6project.com/user_stor/...mission-mount/
Old 12-02-2013, 11:07 PM
grim_ls1's Avatar
That's what I was looking for. For some reason it wouldn't bring it up on summit when I vehicle searched. Thank you.
Old 12-03-2013, 10:47 PM
95LSX454's Avatar
I run an energy suspension poly tranny mount with no issues, great mount!!!
Old 12-04-2013, 06:20 AM
leadfoot4's Avatar
Same here..
Old 12-05-2013, 12:22 AM
grim_ls1's Avatar
And I believe they are. Just some people complain about how it makes the car vibrate more.
Old 12-05-2013, 10:31 PM
95LSX454's Avatar
i had a prothane mount on the car first and it was way stiffer and noiser, then i changed to the energy suspension and it has been good every since
Old 12-06-2013, 09:52 AM
z28bryan's Avatar
Just a heads up... I've heard a lot of people recommend that you want at least the same stiffness or stiffer mounts for the engine over the transmission. They say you want at least poly or solid for the engine if you go with a poly transmission mount.
I have no experience with this, but just a heads up. I would look that up before having him put in the mount. For all I know.. he already has poly engine mounts...
Old 12-06-2013, 06:02 PM
grim_ls1's Avatar
Its rumored that with soft engine mounts the twist of the engine will put more strain on the tail housing. Sounds like it is true. And yes he already has energy suspension engine mounts. Thank you though for the warning as I didn't know this until here recently.
Old 12-14-2013, 07:41 PM
LS1121's Avatar
OK Santa I sold my Poly mount on ebay and installed a rubber mount on my A4, I do have the Poly MM. I sold the tranny mount for a reason I always thought I had a miss in the engine, but install it and you'll figure it out.
Quick Reply: Energy suspension trans mount
