Best drilled Rotors? CTS-V Conversion
Im doing the ctsv front brake conversion on my 02. I just had a simple question, what are they best drilled rotors for this application? I will be running the 2010 camaro rotor not the z06. Is there a particular brand that I should look for? I don't want them to rust so should I be looking at coated ones?
Also, anyone in Houston know where I can get the rotors milled?
I just did the ctsv brake upgrade and used these.
http://brakeperformance.com/brake-ro....php?did=33734
I bought them a couple of months ago, and am happy with them. I like the look and they so far are working out well. The best part of this upgrade is that these brakes look great and do not fade at all. You will enjoy them. Just make sure your backspacing/ spacer sizing is correct for your wheel/ caliper combination.
hth
Andy Schuck
hth
Andy Schuck
I used the NAPA Ultra Premium rotors (Which come with the hats pre painted black, which saves time), Quite a few stops from 150 and in general just beat the hell out of them, they've held up great and I haven't noticed any abnormal wear, fwiw
if your going for looks go with drilled and slotted rotors but if you want the most stopping power then get some solid rotors. drilled rotors have less meterial then solid therefor the have a lower specific heat and will heat up faster. also they are weaker and will crack at least a little.
hear is the sticky on them
https://ls1tech.com/forums/suspensio...brake-faq.html
