Adjustable torque arm w/ relocation bracket
Old 12-17-2013, 10:42 PM
MFCptnMorgan's Avatar
Default Adjustable torque arm w/ relocation bracket
Have a m6 car I just put a bmr adjustable torque arm with the relocation crossmember. I got it set at close to where it was on the transmission and pinion angle set at -3. I haven't tried launching hard from a dig but from a low roll like 10-15 mph it blows the tires away even when I short shift into second and get back in it and it still doesn't have traction. Where do you m6 guys have your torque arm set at on the crossmember?
Old 12-17-2013, 10:57 PM
jsteele90's Avatar
what kind of tires are you running?
Old 12-17-2013, 11:03 PM
Brand new 295 nitto 555rs
Old 12-17-2013, 11:07 PM
Maybe 285 can't remember
Old 12-17-2013, 11:08 PM
babbage1109's Avatar
Is it cold outside....?
Old 12-17-2013, 11:16 PM
It wasn't very cold maybe 45
Old 12-18-2013, 05:13 AM
Tbird232ci's Avatar
Did you do a short torque arm with cross member, or a standard length with relocation crossmember?
Either way, 45 degrees isn't warm enough for most tires to actually hook, not to mention that with the torque arm, you're hitting the tires a little harder, regardless of the instant center and weight transfer.
Old 12-18-2013, 08:08 AM
Nittos aren't usually good until they're warmed up. It's a summer tire the working range is diff
Old 12-18-2013, 09:22 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
this isn't exactly traction season as mentioned above, and Nitto's like to be hot. Do you have lower control arms or relocation brackets? If not I would recommend it. Especially relocation brackets. The adjustable torque arm basically reduces flex, but doesn't change any suspension geometry. The relo brackets however change the angle of the lower control arms and help plant the tires under load
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 12-18-2013, 10:31 AM
zzjdzz's Avatar
Not trying to jack the thread, but is everyone using -3 pinion angle, he stated earlier that he is, as am I, just wondering though...
Nitto 555R will not hook in those temps!!
Old 12-18-2013, 10:37 AM
I have lca relocation brackets putting them on within the week
Old 12-18-2013, 10:38 AM
Reason I posted is because im unsure if I put the front of the torque arm in the right spot. It's standard length btw
Old 12-18-2013, 04:04 PM
Badazz 97 TA's Avatar
Did you have the suspension un-loaded when you removed the torque arm from the rear end? Reason I ask is I have the same one ready to go in, I just don't remember it being easier if you have the car floating or on a drive on lift like I have access to. Any help would be great.
Old 12-18-2013, 04:25 PM
BrntWS6's Avatar
using -1.5* on my MWC setup.
Old 12-18-2013, 06:41 PM
We had it under load. What does moving the front of the torque arm do?
Old 12-19-2013, 08:31 PM
Bump for answers please
Old 12-20-2013, 08:04 AM
UMI Sales's Avatar
Raising the nose of the torque arm moves the instant center and theoretically adds forward traction during launch. Of course this is a trend and not an absolute. All cars respond differently and tuning by racing is the best way to evaluate.
ramey
Old 12-20-2013, 04:19 PM
01ssreda4's Avatar
Pinion angle does not add or subtract traction!
Old 12-26-2013, 03:05 PM
HioSSilver's Avatar
This.....adjusting it is meant to reduce power loss threw the drivetrain and/or vibration. It's a go to for most for traction for some reason. Probably goes back to the leaf spring days.
Quick Reply: Adjustable torque arm w/ relocation bracket
