WS6 With BMR Springs & Bilsteins ( Pic Heavy )
Old 12-29-2013, 07:14 PM
unioncarpenter84's Avatar
Default WS6 With BMR Springs & Bilsteins ( Pic Heavy )
Bilsteins with BMR Springs & Heater Hose Mod
Before:
After:
Old 12-29-2013, 07:21 PM
badformulaLS1's Avatar
Hows the ride/handling?
Old 12-29-2013, 07:32 PM
Only put 15 miles on it so far.
Took it for a ride to make sure there were no strange noises or anything.
Everything seems to be good.
Alot better than stock no doubt about it.
Going to call BMR soon about sway bars for front and rear
Old 12-29-2013, 07:43 PM
How hard was the install?
Old 12-29-2013, 07:48 PM
lot easier than i thought. only took 2 and half hours.
as long as u dont have any rust its easy.
i had more time in taking the sway bar links off and putting new links in and also taking off the master cylinder and fighting with the t-50 torq bolts....then anything else with the install..
Old 12-29-2013, 08:22 PM
Zlow28's Avatar
Looks good, did you measure to see how much you dropped?
Old 12-29-2013, 09:17 PM
no i didnt ZLOW28 i wanted to but forgot all about it. i can messure from the ground to my y pipe because before it was like 4.25 before lowering it
Old 12-30-2013, 07:46 AM
CGCBandit's Avatar
Looks good, I have the same parts ready to go on but with 315's in the rear....should be fun.
Old 12-30-2013, 08:03 AM
Streetlegal?'s Avatar
Here's what mine turned out once it settled. It will drop a bit more for you. I am on the koni lower perch in the front so my front will be lower. Looks great OP gotta love not being a 4x4 anymore Also once you get the sway bars and whatnot from BMR that you are talking about you will love how the car handles. My car feels like it is on rails and I love it.
Old 12-30-2013, 11:26 AM
Did u do the heater hose mod on the rear?
Ya looks good ur front is 3/4 lower because konis right?
How hard is it to make 315s work without rolling fender
Old 12-30-2013, 12:40 PM
Yep heater hose in the rear and the koni lower perch in the front. With the konis you can actually move the spring perch down and it gives about 3/4" so yea.
It's not terribly difficult. With the spacers you wouldn't need much hammering but I would recommend rolling the fender. I need to do that soon as my fenders are slicing my tires.
Old 12-30-2013, 05:47 PM
ya i re did my ws6 wheels stripped and polished them but still unsure if i wana get another set or not i had black torque thurst 17x9 but didnt like them...seems like these trans am are alot harder to find wheels than the camaro..the camaro can fit any wheel..trans am got bigger and wider quarters
i dont wana roll fenders
Old 12-31-2013, 04:32 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Cars look great guys, loving the look with the c5 deep dishes on the vert. Could I get both of you to get some center of wheel well to ground measurements from your cars? I get that question alot and would like to have actual numbers on hand to give people. Mostly about the differences on a ws6 vs a regular t/a or formula. Either post up here or PM me
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 01-01-2014, 09:32 AM
Okay the cars in the garage next time I'm up there I'll give numbers on all four corners for u bmr
Old 01-02-2014, 05:03 PM
Thanks Not a problem I will grab some measurements next time I am over there.
Quick Reply: WS6 With BMR Springs & Bilsteins ( Pic Heavy )
