Tighter Steering
Tighter Steering
ok so im in the middle of a 96 formula restoration. i have replaced a ton of things on the car and its making great progress. i cant help but feel like im driving a cadillac or a big truck with the loose steering tho. Any ideas or solutions to tighter steering?? Im a newbie so dont flame me to bad
Just swap to a duel joint LS1 style, much better. Make sure both bolts are tight on the ends of the stee8ring shaft, this was my problem. The best thing to get better handling is 4.5* or higher positive caster, and put some negative camber in that alignment. I like between -0.5* to -1* camber, gives a nice feel on the road without being darty, and promotes good tire wear.
what you need to do is remove the plastic cover and see if there is play in the joint by having someone else move the wheel back and forth.
here is video that goes over replacing it.
