New shocks and springs advice
I'm redoing my suspension all around, tubular control arms front/back. I plan on getting the qa1 single adjustable gen f struts up front. I don't want to lower the rear bc of my roads but does anyone have any suggestions for the springs and rates. Any thoughts on coil over conversions out back?
LS1Tech Premium Sponsor
I can get you setup with any type of shock or coil-over setup for your application. Ther spring rates will vary depending on your car and what you do with it, but we have a general range of what works best for the stock suspension type f-body cars.
There are several options on the parts you need and MWC has the guaranteed lowest prices along with the street and track experience to back it all up. Give us a call and we can discuss what is right for you.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
The car is my daily driver with the occasional autox event in the future. I'm no pro but would just like to have fun. I would rather carve up some corners then blast down a straight line. Should I get the 300 front and 130 rear?
QA1s (like strange, afco, and viking) are drag shocks, you will be killing your handling if you put those on. 300lbs/in springs are practically stock rates (LS1 stock fronts are 292lbs/in). No where near what you want for handling...
If you want handling you want something like the koni/strano setup (multiple national SCCA titles won on that setup).
http://www.stranoparts.com/partdetai...D=90&ModelID=7
