Advice on best handling suspension.
Got a 2002 camaro had it for about two years and this year I wanted to set it up to take the corners better. It has Strano springs now bmr rear lca, pan hard bar and stock sways and the front is pa racing K member lower a arms upper arms as well. My budget is around $1000. I just order cts v calipers and z06 rotors to help it brake a little better. I put in a few picks of my car as you can see it sits very high in the front cause I have removed a lot of stuff like ac,ac condenser and evaporator a lot of metal was cut out ect. Any advice would be appreciated.
LS1Tech Premium Sponsor
I would definitely recommend looking at shocks and sway bars as your next mods because changing those out will really improve the handling of the car. As far as shocks go the I would recommend the Koni shocks but they are going to eat up pretty much all your budget. If you are looking for something a little more budget friendly the Bilstein shocks aren't a bad option they just won't perform as well as the Koni shocks. If you go with the Bilstein shocks you will have enough of your budget left over to pick up a set of aftermarket front and rear sway bars and still have a little left over. We sell all these parts so if there are any questions we can answer for you or if you would like to purchase them let us know.
Koni F4/F3 adjustable shocks (KON-F4-F3)
http://bmrsuspension.com/index.cfm?p...&productid=849
Bilstein front shocks (BSN-24-024068)
http://bmrsuspension.com/index.cfm?p...productid=1011
Bilstein rear shocks (BSN-24-024075)
http://bmrsuspension.com/index.cfm?p...productid=1012
BMR front and rear sway bar kit (SB026)
http://bmrsuspension.com/index.cfm?p...productid=1210
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I can go a little over my budget and get the konis but I want to lower the front of my car more as well. I was thinking of cutting a coil out and cutting down the bump stop. What do you guys think?
1.2" lowering springs like Stranos are PLENTY low for looks, and are as functionally low as you want to go for handling.
Get the konis and set it on the lower perch, that should help bring the front down. Its not recommended to have lowering springs and konis on the lower perch at the same time, but since you removed a lot of weight out the front then it should be fine.
Now what about chassis stiffening I was thinking of putting in some kind of sub frame connector weld in ones a strut tower brace and 6 pt cage I figured that would be about another $600 are they beneficial or would I not even tell a difference.
some people swear by them others say its worthless, especially if youve done koni's springs and swaybars. when people have done the everything, they would remove the sub frame connectors and notice no difference besides ride comfort increased a bit. but as far as chasis stiffness there was no side effect.
it can show improvement if your on stock suspension.
Lets put it this way, just about any suspension mod will make a WAY bigger difference in handling than SFC's. If you want SFC's, spend money on the important things first like shocks, springs, swaybars and a wattslink, then consider SFC's.
These chassis don't flex anywhere near as much as some people like to make it out to be. The biggest issue is shocks, fix that and you will have a pretty damn good handling car.
fays2.net has all the info u need. honestly if your interested and have time. call Sam Strano at Stranoparts.com, he's extremely knowledgable and is always whilling to help you out and get you what you need and not what you dont need.
