UMI Chassis Mount Torque Arm which mounting hole??
Old 02-07-2014, 10:22 AM
Pharcyde50's Avatar
Default UMI Chassis Mount Torque Arm which mounting hole??
Car is an M6 on BMR Spings, UMI LCA's and relo brackets. I'm currently running the Chassis mount on the top hole. Would the lower hole be better for drag radials and not shocking the tires as hard for a better 60??
Old 02-07-2014, 04:07 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
The higher you mount that torque arm the harder it is going to hit the tire and the lower you mount the lower control arms in the relocation brackets the harder it will hit the tire so you will probably have to play around and find which settings the car likes the most. More than likely you will want to lower the torque arm mount down a bit because you are not going to want to hit the tire too hard especially if the track is marginal with the drag radials.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 02-07-2014, 05:36 PM
Pharcyde50's Avatar
Thanks I'm going make a couple of adjustments.
Quick Reply: UMI Chassis Mount Torque Arm which mounting hole??
