Gunna install SLP bolt on SFCs...
Old 05-11-2004, 11:50 PM
ynkssws6's Avatar
Default Gunna install SLP bolt on SFCs...
Any tips that you would recommend? Like installing them loaded or unloaded? Thanks for any and all suggestions!
Old 05-11-2004, 11:55 PM
Ferocity02's Avatar
I believe you need to install them with the suspension loaded. Make sure you get those bolts REALLY tight. Place a bead of JB weld around the bolt. If they begin to back out the JB weld will crack and probably fall off so you can see it easily.
Old 05-12-2004, 12:23 AM
ynkssws6's Avatar
What's a JB weld?
Old 05-12-2004, 04:07 AM
DARK AGE 53's Avatar
There's no need for JB Weld, the writer of this write-up used it to see if the bolts moved but if installed correctly you shouldn't have any problems. http://users3.ev1.net/~cnl1/firehawk/subframe/index.htm . BTW, this is JB Weld http://www.jbweld.net/ .
Al
Old 05-12-2004, 07:55 AM
ynkssws6's Avatar
Thanks, appreciate it.
Old 05-12-2004, 12:40 PM
HydroDesign's Avatar
That's the worst 'sig' (the stuff in the quotes) I've ever seen ynkssws6. It's pathetic, not funny. What are you thinking?
Old 05-12-2004, 12:49 PM
Copy & Paste Moderator
VIP1's Avatar
Here is another write-up:
http://www.blackcamaro.com/sfc.htm
Old 05-12-2004, 02:16 PM
Ferocity02's Avatar
JB is not needed, yes. But a good idea to use. Not to hold the bolts in place, but to make it easier to check if they are backing out.
Old 05-12-2004, 02:58 PM
LSX Mechanic
Damian's Avatar
Nothing major about installing them, make sure all 4 tires are on a load such as a drive on lift. You DO NOT want the car twisted not one bit..
As for the bolts backing out, i've never heard of it happening. I know two people with bolt on SFC's and never had a problem. Just crank them down about once a year and you're fine...
Old 05-12-2004, 03:00 PM
ynkssws6's Avatar
Who are you to judge anyway? You don't even have a 'sig'.
Get a sense of humor, then maybe you'll think it's funny. It's on a t-shirt they sell in Hot Topic with a pic of an old muscle car on it.
I looked through the first walk through and is calling for me to either make s spacer plate or drill out my SFCs to make the holes larger? Is this true? The second one says that I should just trim a piece off, anyone install these themselves and have a suggestion?
Old 05-13-2004, 11:54 AM
ynkssws6, sent you a PM.
Old 05-13-2004, 08:45 PM
ynkssws6's Avatar
http://mechamperformance.com/index.html
Old 05-13-2004, 09:11 PM
Thumbs up
Nice tips.
Old 05-13-2004, 11:04 PM
VIP1's Avatar
Originally Posted by ynkssws6
What does that have to do with SLP SFCs?
Old 05-13-2004, 11:51 PM
ynkssws6's Avatar
lol, nothing I was I happened to mention the tips to him and wanted to send him the link. Thanks for the link before though VIP1. Dark Age 53, thank you soooo much. I'll be sure to send pics of the install.
Old 05-14-2004, 10:45 AM
VIP1's Avatar
There is some other helpful stuff on that site too.
