Strano rear swaybar
Old 02-14-2014, 07:43 PM
02Z281SC's Avatar
Default Strano rear swaybar
I recently ordered front and rear strano sway bars but i'm not sure if i installed the rear sway bar correctly. Ive searched around but I'm not really sure still. I had no problem with the front sway bar but it just looks like the rear one hangs down really low. The car is on stock springs and stock shocks. Any help is appreciated.
Old 02-14-2014, 09:35 PM
01WS6/tamu's Avatar
That is correct. Next step ditch the junk shocks when funds allow and get a good set from sam.
Old 02-14-2014, 09:39 PM
02Z281SC's Avatar
Ah okay I wasn't sure if it was suppose to hang that low. I already have front koni strs and strano springs sitting around just need the rears. Would it be okay to install them and just leave the stock rear shocks until they ship out?
Old 02-14-2014, 11:50 PM
scj
scj's Avatar
Yeah. Sam made the rear bushings taller to accommodate bolting on a watts link without having to use spacers on the sway bar brackets. If you don't want it to be that low you could swap the bushings to a standard set for energy or something to make the space up.
Old 02-15-2014, 11:07 PM
99Bluz28's Avatar
This will get your bar back up higher.
Energy Suspension #9-5158G, about $16 for the set, or $21 shipped.
http://www.summitracing.com/parts/ens-9-5158g/overview/
Old 02-16-2014, 08:54 AM
Marc3.4V6's Avatar
Weird, mine seems closer to stock. I torqued the brackets to stock spec, was I not supposed to? I did tighten the endlinks as Sam suggested though.
Old 02-16-2014, 11:35 AM
sscamaroburn02's Avatar
My strano bar does not hang that low. The bar is almost even with the pumpkin. Did you torque everything with suspension loaded?
Sent from my HTC One VX using IB AutoGroup
Old 02-16-2014, 02:50 PM
99Bluz28's Avatar
That because you car is lowered, which pivots the center area on the sway-bar up higher.
Old 02-16-2014, 03:21 PM
Zlow28's Avatar
Mine looks like OPs aswell. Stock springs for now.
Old 02-16-2014, 08:41 PM
Mike Morris's Avatar
Same here and mine is not lowered.
Old 02-16-2014, 09:30 PM
Daniel Richards's Avatar
it's pretty clear to me (anyway), because I have replaced my rear sway bar and with it did new bushings that beyond any shadow of a doubt it is as described above, the bushings are TALLER pivoting the center down more then normal.
Old 02-16-2014, 10:03 PM
02Z281SC's Avatar
I plan on lowering it with strano springs. I have them sitting in garage just waiting on shocks but that should bring it up a little correct?
Old 02-17-2014, 12:55 AM
camarokid91's Avatar
The reason for Sam bar to hang lower is because it is setup out of the box for the addition of a watts link.
Old 02-17-2014, 01:12 AM
99Bluz28's Avatar
Yeah, I was wondering what ever was done about the sway-bar munt U-bolts being borderline to short when using the Fays2 watts-links spacers.
IMO, that was a good solution.
Old 02-18-2014, 10:07 AM
Midnight02's Avatar
It seems there's two items at play here: Sam's bushings are a bit longer to accept the Watts-link and the OP's car is at stock ride height.
I presume lowering would help move the bar up in relation to the pumpkin. If you're not going to run a Watts-link, is there any harm in using the energy suspension bushings on a lowered application?
Old 02-18-2014, 12:34 PM
99Bluz28's Avatar
I don't see how there could be any issue with using the shorter ES bushings, Strano's rear bar was using shorter bushing before without any issues. Either way unless he's have a ground clearance issue with the center of the sway-bar being lower he'll be fine with the taller bushings.
Quick Reply: Strano rear swaybar
