Need opinions on budget shock/spring set up
I have a 99 SS with stock decarbons and the pro kit. I paid $100 for the springs so they were a good deal to me. I obviously need new shocks and struts but I can't afford konis.
The car is not raced period, it is a Sunday driver that I want to look good and ride better. I know the pro kit is soft, I feel it on every big bump, but I can't help to think it is BC of the decarbons. Can this be remedied with better shocks?
Out of the cheaper shocks on Strano`s site, what is recommended? Bilstien, koni str.t, tokico, kyb? I'm looking to stay around $400-ish
I'd go with either the Bilsteins or Koni STR.T.
BTW, you can also get the Bilsteins for about $368 shipped.
http://www.ws6project.com/user_stor/...age-set-of-4-/
LS1Tech Premium Sponsor
The STr.t's will be a perfect choice for your application. Not sure where you heard that about them not being designed to work with lowered vehicles, because that it completely false. Bilsteins are not a bad choice for the money either and may be more readily available. The Str.t's are out of stock most everywhere. They are selling faster than Koni can make them it appears.
I have the Eibach Sportline kit, which is pretty low 2.5" or more. My Decarbon shocks seem to bottom out...especially in the front! Which shocks would u recommend for mine? Are these shocks shortend for lowered applications?
There are SO many threads on this site about this question. That's how I made my decision...just searched for days looking to see what people were saying about them....ended up going with bilstein and bmrs. It's all about preference and application IMO. I dd my car and couldn't spend a thousand dollars, therefore I went with Bilstein.
BUT...if i COULD spend a grand or more, I'd call sam strano in a heartbeat! This man knows our cars suspension like no other! Just read up on what he has to say about bilstiens, and konis...
and btw the koni orange (str.t's) are on backorder.
IMO, any of the following lowering springs(1" -1.3" drop) would be a better choice: Strano's, BMR, H&R, Vogtland, Hotchkis .
Anyway, yes better shocks will still help some with the Sportline springs, but they won't eliminate you issue because of the very limited shock compression travel you'll still have with the extreme lowering.
Ive done the search, but couldn't get the solid answer I am looking for. I have the pro-kit, and want new shocks/struts. I keep getting mixed answers in regards to what to use other than the obvious Strano/Koni set up. I can't afford to go that big, so I am trying to get advice from people with actual experience.
I plan to do business with Strano, and I know he knows his stuff. I'll just PM him. Thanks guys.
LS1TECH Sponsor
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Regardless of which shocks you go with you'll basically still be right on the bumpstops with the Sportline springs, which most will agree lower too much!
