Help with tire contact patch diagnosis
I have a real bizzare contact patch on my rear tires. Really, these tires were on the front for about 15k miles and have only been on the rear for about 1500 mi.
The car is a '99 Formula, completely stock, with 76k miles.
The tires are wearing normal, as the previous tires have.
Here are the pics:
Driver's Side
P***enger's Side
Anybody have any ideas as to what would cause this?
Here are the pics:
Driver's Side
P***enger's Side
The only time I got feathering like that was from not rotating the tires.
If you left them on the front for 15k that was too long.
My experience with tire wear like that is it's set, and will continue to wear that way.
Copy & Paste Moderator
Originally Posted by camy
It's definately not an inflation problem. If I wash away the dust, the tread wear looks even across the entire tire.
These tires are Bridgestone RE-730's.
It's called cupping or scalloping and it makes since that they were on the front. That's usually where you see it happen. I'd get them rebalanced first but it could be a sign of worn shocks or worn steering components.
I run the tire pressures 32 up front and 28 in rear. This is what I've gotten the best wear with.
I thought it would be shocks, but I wanted to hear it from someone else.
Thanks
Thanks
Originally Posted by VIP1
32 & 28 psi?
I run 31.5psi all the way around on the stock 245-50-16 Goodyear Eagle GS-C tires.
Todd, I'll check the steering/suspension components when I replace the shocks/struts.
The weird thing is that the tires are not wearing badly, visibly. If it weren't for the dust on the tires, I'd never have noticed.
When I originally posted this, I had intentionally left out some information. Here is the long, full story.
When these tires were put on, I had an alignment. About 5k miles later, I drove the car (this is my wife's car) and noticed a noise from the front which I took as tire noise. I asked my wife about it and she said she never noticed it and it didn't bother her. I checked the hubs and they were tight. I also kept a close eye for abnormal tire wear. I did try to get the tire shop to look at it, but because the tires were mail ordered and it was over 6 mo since the alignment, they wanted to charge me a good bit of $$$ and I declined.
Well, at 15k miles, I'm starting to drive the car more than her and the noise drove me crazy on just one trip to/from work. I rotated the tires and the noise quieted down considerably, but didn't go away. Now, 1500 mi. later, it's back and as annoying as ever. This tells me it's not a tire balance problem and has something to do with alignment or suspension/hub/steering. I ruled out an alignment problem due to the wear on both the inside and outside of tire. I'd have to have some real sloppy tie rods for this to happen and I don't believe they are. Again, I checked the hubs and they are real tight.
So, I've purchaced shocks/struts and will try that now.
Yep, the rear tires tend to wear in the center and the fronts on the edges. Hence the 5psi difference. I guess a normal tire rotation would take care of it, but I'm too lazy for that.
