Lowered 4th gen clearence issues?
Old 03-17-2014, 06:53 AM
SSGunn's Avatar
Default Lowered 4th gen clearence issues?
Im about to order a set of lowering springs for my Camaro. 1.5" all around. Im currently running 18x9.5's in the front and 18x10.5's in the rear. Front has P275/40/R18's and rear has Mickey Thompson ET Street P305/35/R18's. Will i run into any clearence issues when i lower the car? Will i need to cut/roll the fender wells or just BFH? My next set of rear tires are going to be Nitto NT05 P305/45/R18 so i excpect ill have to do some work to make those fit. But can i fit my current setup without any problems? Let me know if this setup works and if anyone has any pictures please post!
Thanks!
Old 03-17-2014, 08:29 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
You are definitely going to need to use a BFH to clearance the inner wheel well back there and there is a possibility that you may have to roll the fenders also. That 1.5" drop is a good drop and a bit lower than we are used to working with since our BMR lowering springs are a 1.25" drop.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 03-17-2014, 01:54 PM
sscamaroburn02's Avatar
U may need to in the rear with 45 sidewall ratio. That is a good bit of tire. Also nittos tend to run smaller than other brands
Sent from my HTC One VX using IB AutoGroup
Old 03-17-2014, 03:59 PM
unioncarpenter84's Avatar
sent u a pm for lowering springs
Quick Reply: Lowered 4th gen clearence issues?
