? for those who've done Moog replacements
Was wondering if you may have specific part numbers for the front control arm bushings, upper and lower. I'm going to do some ordering and want to make sure I'm getting the correct ones. I thought I remember someone offers a "kit" that has all the bushing, etc. in it
Thanks
Thanks
Thanks for the replies!
So there is a total of 3 (per side), 2 uppers (one used on the lower arm) and second bushing that is also used on the bottom? 6 total?
Looks like Strano has a "kit" you can buy, anyone know the brand he uses? Worth it or better to just order from Rock Auto or something like that?
Thanks again
Thanks again
Order these parts from Rock Auto:
Moog K6490 (order 2, 1 set for each side) Front lower control arm bushings (this includes both the front and rear bushing instead of buying them under 2 separate part numbers)
Moog K6689 (order 2, 1 set for each side) Front Upper control arm bushings
Moog K6145T (order 2, 1 for each side) Lower Ball Joints (these are greasable)
Moog K6462 (order 2, 1 for each side) Upper Ball Joints (these are greasable)
these total to a little under 200 shipped (with the 5% discount that is easy to find from rockauto) this is basically this kit from Strano http://www.stranoparts.com/partdetai...D=18&ModelID=7 minus the rear control arm bushings, Sorry Sam but NOBODY comes close to the prices on Moog parts that RockAuto does.
but, if you're going this far and haven't done them yet go ahead and get the tie rod ends and inner tie rods, no point in doing all this stuff and leaving those parts as stock.
Thank you much for posting these! So far I've done, shocks\springs, outer tie rods, new tires, PHB, LCAs, tower brace, car had weld in subs when I got it. Really want to tighten up the rest of the front bushings and do sway bars. Can't wait to feel how it rides/handles afterwards. It still feels a little sloppy to me right now. In between my Camaros I was driving a Mazda RX8 that rode on rails. Trying to remind myself that I'm not in that car anymore, but I still think this Camaro has more to offer.
