Is this wheel hop? concerned...
Right after the 1-2 shift, when I dump the clutch on max acceleration, it feels like something is jumping up and hitting the floorpan. It doesnt happen all the time, but most of the time. a dsm friend of mine mentioned that it could be a broken tranny mount, but he said he doesnt know much about f-bods. any ideas? I havent actually gotten under there to look yet...thanks
In my experience wheel hop feels something like driving over a washboard road surface. It'll cause the rear axle to shake or vibrate up and down when you're trying to get traction and will shake the **** out of the car's interior. This is usually pronounced on launch though, moreso than a shift.
If what you're describing is just one or two thuds/clunks on the floorpan then I would suspect the Y-pipe hitting the floorpan. Do you have an aftermarket Y-pipe? If so, then your clearance may be too tight. If not, then it could very well be due to a tranny mount or motor mount problem.
Just speculation of course...
All I have done to the car is a lid, filter, and loudmouth cat back. when this hard thunk occurs, the tires dont really break loose on the 1-2 shift, which they did when the car was new...
also, this doesnt happen when I do a burnout in first gear at all...that is totally smooth...only on the 1-2 shift under maximum acceleration...although it feels as though it is coming from directly underneath the front cupholder which is why my DSM friend suggested the tranny mount...would that be a warranty item?
Based on your description it really sounds like Y-pipe (or maybe tranny) banging the floorpan to me. I doubt the LM exhaust would be causing the problem, so it does sound like a warranty issue to me. The tranny mount is a cheap and relatively easy thing to replace, so if you're nervous about coverage or have a shitty dealer you might consider checking that yourself first.
Originally Posted by Zero_FactiX
What about the I pipe hitting the Drive shaft I had that problem when i put My Hooker Catback on. Just had to bend the pipe a little.
Originally Posted by frey51
my LM comes loose there too, but I have a stock Y. Soon to be fixed in July with flps.
i vote for wheel hop. my friends t/a did it and whatever was in the cup holder shot up. i dont think it coudl be the tranny mount if u can do a burnout adn not hear it. when u get heat in the tires it cleans the **** off lettin them spin smoother. what tires u have? its not lowered at all is it? if it was the tranny mount it would do it all the time. mine had nasty wheel hop all stock
Originally Posted by TheSloth
sounds like a tranny mount to me... same thing was happening to me on the 1-2 shift until i put in one of those poly mounts
well the torque arm on a burnout would push the trans down on the mount and then when you shift its letting up on it causing it to hit the floor..i would agree its a tranny mt. problem..i know i know you dont wanna get ur clothes dirty but you might have had it figured out by now...
Originally Posted by JLMoses
a friend of mines Fbody did that and it was the Traction control doin something funky if i remember correctly
