brakemotive
Just installed the Brake Motives this weekend and so far so good. The pads are the Power Stop Z16's. The rotors look good and stop the car.
I was sent the wrong rear brake pads, 16-755's. Contacted customer service and they emailed a return label as well as the proper pads, 16-705's. Will probably order a rotor/pad setup from B'Motive for my GTO soon.
How long did it take and did the give a hard time cuz this is day #3 and ive called 3 times and im still waiting for a tracking label. I'm very patient but I don't like being mislead.
I bought their rotors a couple years ago from Ebay and they look and stop good - and are super cheap. easy mod and upgrade! a little off topic, but only problem I ran into was passenger rear bracket bolts were on so tight I busted 2 ratchets using a pipe as a handle extension. Had to soak in PB blaster, and take to a friend's shop, put it on lift and use air tools.
