Park Brake Help
Old 03-31-2014, 10:34 AM
YellowTA1's Avatar
Default Park Brake Help
I went to get my car inspected Saturday, and it failed because the park brake would not hold. Now, some background, the car had been sitting for almost 2 years (long story) so do I just need to bleed the brakes? It has pretty new rotors and pads on it.
Old 03-31-2014, 10:41 AM
_JB_'s Avatar
You have to manually adjust the parking brake. Search this site and you'll find everything you need to know.
Old 04-01-2014, 02:11 PM
Save the manuals!
wssix99's Avatar
^ Right. Typically people don't know to do this (or forget) when the rotors are changed.
Old 04-17-2014, 02:46 PM
imma_stocker's Avatar
Parking brake is cable operated drum brake. Bleeding brakes is a good thing but utterly pointless for the hand brake.
Try greasing the cable from inside the cabin all the way under the car to the backing plates. You might have some bind or something in the way causing it to stick. Without full travel and movement the cable might have too much slack. If that doesn't do the trick then you need to tighten it.
Quick Reply: Park Brake Help
