Chassis Improvement on Stock F-body
I have a '98 Z28 M6 with t-tops 60k miles on it. I'd like to do some stuff to stiffen it up and improve handling. In the summer it is a daily driver. And I only drag race it a couple times a year. So it is really just for my own enjoyment on the street that I want better handling and a stiffer chassis. I am thinking of getting 3 point bolt in sub frame connectors (I want the bolt ins for now so that I could take them off if I wanted to do exhaust later) and after doing the exhaust would probably have them welded in. I don't want to go to extreme. I just want to have an all round more solid feeling car and other than sub frame connectors I don't really know what else to do.
I considered a strut tower brace, but I hear that they are more for looks.
Currently it is bone stock with an MGW short throw shifter on the way (just ordered today )
Personally I like my strut tower bar, yes it's not as noticeable a difference as say one on a mid 90's honda civic, but it does have a small effect, of everything i've done so far it was the smallest change but it helps when you need to reach in the bay to have something solid to support you instead of putting your hand on the cowl.
I've heard SFC's can reduce squeaks and rattles by stiffening it up. So even if the handling wasn't hugely improved. I like that it wouldn't squeak and rattle as much.
That is exactly what SFCs will do. It will stiffen it up without improving the handling all that much. So if that's what you want, by all means do SFCs. Just be aware that stiffer shocks/springs/swaybars will also stiffen it up as well as improve handling a lot. Up to you to decide which you want.
In doing something that truly wasn't great thinking, last summer I had all the shocks and struts replaced, but I didn't even think about uprgrading them. So it has basically brand new shocks and struts (less than 5k miles on them), but they are only slightly better than OEM quality. The mechanic I took it to got a mildly upgraded set. It definitely feels better than it did with the original ones, but I'd still like it to feel much better, but I'm not really ready to replace all the shocks and struts again.
I know you'll hate reading this but good shocks will reduce/eliminate rattles while providing a vastly improved ride and drastically improved handling and feel. Easily the single best mod for these cars, nothing else compares.
You can add swaybars but the car still won't feel great or handle all that well because of the poor shocks (mileage being irrelevant if the dampening isn't up to par in the first place when they are brand new).
SFC's have said to reduce squeaks and rattles, but its definitely not a sure fix, as the true issue is still at hand: poor shock dampening letting the harshness transmit to the chassis in the first place.
Hey, you're only hurting yourself man. Id take those off and try and sell then and buy yourself some good shocks.
