Pic included....What is this bar?
I just purchased what I was told was a BMR trackpac (not 100% sure if it is truly a BMR or not) anyway, in the pic the bar all the way to the right, what is it? The others I know are sub frame, LSA and tq arm. But the last one is too thick to be a panhard and does not have proper ends anyway.
So what is it?
So what is it?
LS1Tech Premium Sponsor
That does appear to be our track pack arm.
To install this setup you will need to install the sub-frame connectors first, then the long crossmember will need to be cut to length and welded in between the SFC's for the torque arm to mount to. Here is a picture of the setup installed to give you an idea
So what is it?
So what is it?
