Need some part numbers
Hey guys, in the process of doing a spring, strut, swaybar, and full front end rebuild. I thought I had all the parts I needed, but after taking the struts off I was wrong. First part I need is the isolator that goes between the body (frame, chassis whatever you want to call it) and the all steel strut mount. Not the one that goes in under the shock nut. Second is the the all steel strut mount itself (upper control arm bolts to it). I pulled it off and about a 1/2" of rust was falling off where the isolator sits. If anyone has part numbers would be a great help. Im thinking the strut mount will have to come straight from GM. Thanks
This link might help you out. It has a diagrams.
You can also do a search for "98 02 camaro parts manual pdf" to get the GM one.
http://www.gmpartsdirect.com/catalog/frameset.cfm
