seized brake piston
seized brake piston
In the middle of my ls1 brake swap I couldn't get the one piston on the drivers side piston to compress no matter what I try, buying and replacing the control arms used up all of my emergency money so I'm broke until next Friday and I need the car back tomorrow for work. Can anyone help? I think I'm screwed.
Got an air compressor? Take the caliper off and take out the bleeder screw and put an air nozzle up to it and try to press the cylinders free (put a board in there so they don't shoot out across the garage/shop-because they will lol)
Assess any issues once you get them out.
this happened to me on saturday
I had no luck with compressed air, but I was able to stick a block to hold the good piston and just press the brake to get the other one to move outward. I didn't pop it all the way out, I just wanted to see if it moved at all and whether or not I could push it back in afterward
I don't screw around with brakes though. If it's frozen it's probably rusty, and if it's rusty it's probably pitted. I went and just bought a new caliper.
