Keep 1le springs or stranos
Gotta 2001 hawk with factory 1le springs. Just bought some koni str.t shocks and was wondering if I should upgrade to strano springs or keep the 1le springs? Anybody care to shed some experience with either combo? Thankw
LS1TECH Sponsor
Question 1: Do you want to lower the car? That's a big one.
Question 2: What is it you want from the car?
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
The car has heads and cam. I'm currently saving money for a 9" but my intentions are not for track only. I'd like to be king of the street, too something that will provide a very street able ride paired with my koni str.t shocks i just ordered. However, once I get that 9" probably wouldn't mind to hit the track every once in a while.
If you want to keep the same ride height I would swap the rear 1LE springs for base Z28 springs. The 1LE rear springs are a little stiff and will limit launch traction.
I'd defer to Sam or others on lowering springs.
yeah, I don't think I could afford to lower the car too much. What is the typical drop with the strano springs? 1.25"? It has true duals, which are tucked semi decent, but I don't want to be scraping if it does get lowered. Then again, it's not a daily driver. They're not the aftermarket 1le springs, the car came factory with the 1le option. Granted that was 13 years ago, so I was wondering if it was time for an upgrade anyway.. Thanks for the input guys.
LS1TECH Sponsor
1LE front/Z28 rears would be my choice if I was going to stay on "stock" springs.
__________________
