A way to create a "lower perch" on other shocks
I was looking at a spare lower spring perch for the front shocks and got to thinking. A shortened perch that gives an extra 1/2" drop in the front without requiring a lower ring on the shock body itself doesn't look like it would be too hard or expensive to make. Effectively allows for a "lower perch" on more shocks.
Am I crazy?
Heck, it could be taken another step and a "coilover" style adjustable sleeve that would still use regular springs like oem, strano, etc
This is when I wish I could fab stuff.
Am I crazy?
LS1Tech Premium Sponsor
Koni Sport shocks offer this option similar to what you are talking about. A lot of people like to call them "adjustable" but I don't think that is a fair term for how they are configured. They have an upper and lower perch position, which are basically snap-ring grooves about 1/4" apart on the shock body. The spring pad seats on the snap ring in the groove to locate it.
I see what you are saying, however the issue becomes the replacement of the entire perch. The factory DeCarbon shocks have a retainer on the top of the shock body that will not allow the perch to slide off. Removing this retainer means actually opening the shock up. I don't think that would be something that most people are equipped or prepared to do.
did this quick sketch to show people what you mean. Shortening the center height in the lower perch would allow for a more agressive drop option while still using the BMR or Strano or Even stock springs, this would allow the front to drop on any shock with a replaceable lower perch as an alternative way to the way Koni does there's, IE shocks without multiple snap ring locations could use the shortened version to create the same effect as the lower snap ring position on the koni's
You could also cut out the center section up at the top of the straight section, then have the center of the spring seat opened up just enough to slide the cut off center section up into the spring seat and then weld them together. I would have a shop with all the proper machine tooling do the work.
That is what I am saying is the issue. Replacing a spring perch on a factory shock is not as simple a task as most weekend garage guys are willing to tackle. Taking that retainer off is one part of it. Getting the factory perch off the shock and an new one to fit down over it is a chore in itself. Your idea will work in theory, but what I am saying is for the cost of the part plus the time and effort involved in installing it, you would not be ahead anything over a regular set of drop springs.
even then it would still give those guys that are looking to swap out the factory shocks to like Bilsteins or something an option to lower the front just a little, like what you get with the heater hose mod in the rear, so you get some minor drop but still retain the factory springs for those that live where even the 1.25" drop of the BMR's is more then they can do without scrapping on there driveway. There is a crowd out there that wants to be a little lower but still keep the stock springs for ride comfort. I did it for a while on my last honda used the lower snap ring position with the stock springs.
Some people may just want to drop only 1/2" or so.
Or maybe they want to go a little lower than 1.2" drop springs will take them, but without resorting to crappy pro kit springs.
Or maybe they have done weight reduction and the 1.2" drop spring doesn't get them that drop anymore. Or in my case, my V6 isn't heavy enough to drop that last 1/2" lol. I don't want to shell out for Koni Yellows just for a 1/2" additional drop.
Pontiacerator
Sparky's idea would mean manufacturing shorter perches, which should be able to be done for far less than lowering springs. You install them on your new pair of Bilsteins and you get a .75" drop just like with Konis, but for much cheaper than they are or new springs.
Think of a price point around $25-35 a pair ... realistic?
yeah up to 50 would be about the peak price point, after that people would just start looking at investing in better shocks, but being the Moog replacements at rockauto are like 10-15 each I think 50 would be a fair price for something like this, the question is are any of the sponsors setup to manufacture spring perches like this? if they had to bring in special equipment I'm not certain they would turn a profit on these, while i'm sure there is a market I don't think it would be large enough to cover costs unless they could do them already.
