question about coil springs
how would you know you need new springs (not shocks) on a vehicle?
how would you know or figure what spring rate to choose? I assume it's based on vehicle body weight that's sitting on top of the springs?
forgot to mention: 2002 camaro ss with SLP bilstein suspension package.
can someone tell me the spring rates and shock rates/values if there is such a thing of what the base model camaro/ss would have had vs what I have with the slp bilsteins?
thanks.
thanks.
LS1Tech Premium Sponsor
thanks.
thanks.
If you think your springs are sagging I would recommend checking the ride height on all four corners to see what they are at.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Attached are 2 pictures, the one at the gas station is before I did any suspension work on the car, the one in the gravel driveway is after I installed BMR springs and Bilstein shocks ONLY on the rear of the car. Notice how the front end now sits level where it used to sit noticeably lower, this is a sign of sagging springs (in my case the fronts having sagged more then an inch from where they should be), So once I can get the down time on the car I will be tearing the front apart to replace shocks, springs and while I'm there ball joints and control arm bushings.
thanks.
thanks.
As for shocks you will notice the car is getting more and more loose, floaty, disconnected and bouncy if they are going bad.
For choosing spring rate that depends on what you want to do with the car (Drag vs handling), and what height you want the car at.
Here is a list of some spring rates for fbodies:
http://www.angelfire.com/my/fastcar/suspension.html
