Shackles/spring clamps OK for small drop?
Old 05-17-2004, 06:33 PM
Y2K2LS1's Avatar
Default Shackles/spring clamps OK for small drop?
Are they okay to use for a small drop like 1/2 - 3/4 inch? I dont want to get into springs and shocks and all that. If I can get 3/4 inch with no ill effects cheaply than ill do it.
Has anyone here used clamps/shackles?
Old 05-17-2004, 06:57 PM
trackbird's Avatar
I'd stay away from those. But you can remove the rear spring isolator and lower the rear 3/4 inch. But, the front will need Koni SA's which have a 1" lower mounting point for the springs that you can use to lower the front. The good news is, you can get great shocks (for the front) lower the car and improve handling all at once. If you upgrade the rear shocks, the change will amaze you. I'd not cut or clamp them though.
My thoughts.
Old 05-17-2004, 09:12 PM
Y2K2LS1's Avatar
My thoughts.
I don't want to spend a fortune. So how much are these konis? And I can use the stock spring in the front?
Old 05-17-2004, 09:45 PM
trackbird's Avatar
I suspect that we'd be over budget. I was thinking and typing at once and since I had it typed out, I posted it. I can tell you where to get rear Koni SA's for about $80 each. Fronts are about $439 a pair. It will let you use stock springs and you'll be amazed at what good shocks will do.
I was thinking that lowering the rear is cheap. I forgot about needing shocks in the front (until I was done typing it).
Either way, I'd avoid the shackles and such. I'd cut the springs first. And I absolutely hate/don't believe in cutting springs. If that tells you something.
Old 05-18-2004, 02:17 AM
Jeffs99SS's Avatar
Yeah, you really want to avoid them if you can. Some people have had luck with MINIMAL cutting of springs. You need to be carefull, though, as this can lead to a poor ride if cut too much.
Jeff
