Experience with coil overs
Old 05-22-2014, 06:29 PM
Fosnot's Avatar
Default Experience with coil overs
I'm looking for some input on which company makes the best coil overs as far as widest adjustability goes... I was looking at a set of AFCO double adjustables all the way around which ws6store has for ~1440 or so... would there be a better route to go/higher quality coil over set available without going to $2000+ for a set...?
Thanks for your input
Old 05-22-2014, 10:05 PM
camarokid91's Avatar
There's some coilovers on frrax. They are rather extreme and geared toward racing only.
[quote name='GNBS' date='Mar 1 2014, 04:00 PM' post='177554']
I am selling a practically brand new setup (was used for 40 minutes at Road Atlanta before the car was totaled--and no I wasn't driving lol). This is the race Bilsteins, adjustable coil overs, 1000# front springs and 400# rear springs. It was setup to run the UE lowering PHB brackets, but I am not sure if I can get the ones I have back off without damaging the brackets or the rear end. This setup was $2K without the drop brackets or Afco spring locators ($70 extra, but included). I will sell everything pictured for $1500 shipped. Thanks
[/quote]
Old 05-22-2014, 10:40 PM
Fosnot's Avatar
Damn 1000 and 400 rates are a little bit more than I was looking at! I bet that thing would annihilate the corners. I'm looking for more of a drag setup that I can adjustable to have very good street manors and not turn into a total boat.
Any input on such a setup?
Old 05-23-2014, 06:12 AM
UMI Sales's Avatar
Afco's are nice as are Vikings.
Check this page to see the Vikings along with our new rear coilover kit.
http://umiperformance.com/catalog/in...v50golupjofdb1
Let me know if you'd like help selecting the rates.
-- Ramey
Old 05-24-2014, 10:37 AM
Fosnot's Avatar
What interests me about the Afcos, is from there description anyway, the adjustment almost resembles that of a spool valve shock without any physical 'clicks' or specifici increments you have to utilize. Of course for the price of ~1400 for a set they can't be true spool valve shocks but the resemblance is slick.
What I was hoping was that someone would chime in with experience in any of them; ups and downs of one particular coil over vs another. Again with a bias towards drag but still looking for great street composure.
Old 05-24-2014, 07:23 PM
Firebirdmuscle's Avatar
I would contact Eric at MWC or he'll probably chime in here to as well, but I would highly recommend the viking da. 18 adjustments in c and r so you have range to find your sweet spot you like. I currently only have experience with the rear but will have fronts too eventually
Old 05-24-2014, 09:25 PM
99Bluz28's Avatar
I would look at DA's for the front(at least), since good ride/handling and drag settings will be almost opposite (high R/low C, vs high C/low R) and adjusting for both to your liking will be more possible with DA's vs SA's shocks.
Old 05-25-2014, 01:13 AM
Fosnot's Avatar
Yes, all the shocks/coilovers I'm looking at are all double adjustable.
Quick Reply: Experience with coil overs
