Long Acre Magnetic Mounting?
Old 06-04-2014, 01:12 PM
Cthulu's Avatar
Default Long Acre Magnetic Mounting?
Anyone use the longacre caster camber gauges?
I'm not seeing how the magnetic ones mount when you have aluminum wheels.
Old 06-04-2014, 01:52 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
your best bet would be to take the wheel off and use it on the steel center hub. This would be much more accurate anyway than that of the surface of a spoked wheel
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 06-04-2014, 02:33 PM
BMR Tech2's Avatar
Just make sure to load the suspension to check these specs first using either a jack or a stand as close to the balljoint end of the arm as possible to simulate actual wheel load.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 06-04-2014, 02:42 PM
Cthulu's Avatar
Thanks man, good tips.
Old 06-08-2014, 07:10 AM
FASTFATBOY's Avatar
Have you seen this?
http://www.quicktrickalignment.com/
Old 06-09-2014, 12:06 PM
Cthulu's Avatar
That would have been perfect, already picked up the longacre stuff though.
Quick Reply: Long Acre Magnetic Mounting?
