Removing front swaybar and brackets
I took off my front sway bar and my car had the extra drivers side bracket and I also took off the little shroud/ splash guard thing that the sway bar went through. Should I put that back on or leave it off? Looks like it might protect the alternator or something?
I ran a long time without one, someone who worked on the car removed it without my permission. I was going through a lot of failing alternators so I ordered a new one while they were still available. They weigh practically nothing, and if it offers some peace of mind, I'd say put it back on since you still have it.
I would just relocate the alternator if its that big of a problem. With that in mind I lived in Washington were it rained for months straight and didn't have the splash guard. I had no problems at all. The alternator was in the stock location. As for Sway bar removal question. I removed that as well its rumored to help with weight transfer/ weight lose. Did it help ? I have no idea. Only time I even noticed its gone is when I push really hard in corners. Other than that nothing really noticeable. Now on the other hand I did remove the front Sway bar on my Silverado and its a BIG difference. Weight transfer is noticeable until tires loose grip then it just comes back down. Worth it Sure
