Single or double adjustable shocks, front and rear, and what lb springs?
What I really want to know is what lb springs are recommended for a drag only car front and rear. Its a 99 WS6, weighs about 3,400lbs with me in it but always cutting out more weight here and there, T-56 trans. Thinking about getting single adjustable shocks unless someone can talk me into double adjustable.
LS1Tech Premium Sponsor
If it is a 6 speed car, I would definitely look into some double adjustables for the rear. For what you are doing i would look into the Viking setup for all 4 corners. They offer a coilover front and a direct replacement rear shock. For the front springs at that weight, I would look for a 300# rate on a 14" spring. Give me a call and we can go over some options as far as getting you setup with everything you need
