UMI Adjustable Uppers
Old 07-08-2014, 12:13 PM
RedLSWON's Avatar
Default UMI Adjustable Uppers
I had the UMI adjustable upper control arms with new ball joints installed recently. Ever since then the front end is very noisy over bumps (Like a squeaky/popping sound?). I'm just wondering if this is normal because my car never made these sounds before.
Thanks!
Old 07-08-2014, 04:06 PM
79_T/A's Avatar
Do they have poly bushings or the spherical rod ends? If poly and squeaking, they aren't properly greased. If rod end, they will transfer more harshness and vibration through the car.
Old 07-08-2014, 07:53 PM
RedLSWON's Avatar
http://www.code510.com/1993-2002-cam...ance-2310.html Im not for sure but heres the link to them. I believe they are the rod end.
Old 07-08-2014, 11:19 PM
99Bluz28's Avatar
As long as the jam-nuts on the rod-ends are tight they should be fairly quiet. The rod-ends don't start getting noisy until the lining wears down and creates play. I'd also check to make sure the 3 bolts on the upper ball joints are tight.
Old 07-09-2014, 07:10 AM
UMI Sales's Avatar
As others have said, tighten jam nuts and assure the ball joint is tightened well. Rod-ends are not known to be quiet; you have to remember we're putting a solid rod-end where there used to be a rubber bushings designed to isolate noise/vibration/harshness. So it's normal to add NVH when using Rod-ends.
Hope this helps!
Old 07-09-2014, 08:36 AM
RedLSWON's Avatar
Thanks everyone I will check them this evening
Old 07-11-2014, 12:26 PM
jrwilliams95z28's Avatar
not trying to hyjack the thread, but I have the same upper A arms and am wondering if I can switch them to Roto-joints or will they not fit?
Old 07-14-2014, 09:07 AM
UMI Sales's Avatar
We do not offer a Roto-Joint for a bushing that small.
Old 07-14-2014, 10:12 AM
ok cool! good to know lol
Quick Reply: UMI Adjustable Uppers
