Lowering springs and shocks?
I just bought a all stock 2002 trans am ws6, and i was wondering which lowering springs are the best that will give me a smooth comfortable and level ride? post some pics!
well, it's not just about the spring, yes the spring is important but even the best springs will ride like *** if you pair them to a crappy shock, like the factory decarbons.
the best springs are either BMR or Strano but you need to match them to at least the Bilsteins or Koni STR.T's (for those on a budget) or if money is no matter get some of the really nice double adjustable koni's.
also don't forget an adjustable panhard bar to recenter the rearend and likely new mounts for the front shocks.
personally I have the BMR/Bilstein setup on my car which I daily drive and like it fine, in some places it harsher then stock (but your gonna see that with any lowering since they are all stiffer springs then stock), I also had all new bushings installed in the front control arms when i had the fronts installed due to the age and mileage on the car which really helped smooth the ride out.
LS1Tech Premium Sponsor
It really depends on what your budget is. If you are looking for something a little on the cheaper side I would recommend running our BMR lowering springs (SP001) along with either the Koni STR.T or Bilstein shocks. Both of these shocks are non-adjustable and work well with our lowering springs. If you are looking for something a little more performance oriented and have the budget for it you can use our BMR lowerings springs (SP001) along with the Koni yellow shocks which are adjustable and will allow you adjust the shock valving to optimize the performance and handling of your vehicle.
If we can help you out in any way please let us know.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
