What lubricant/grease to use on caliper guide pins?
Just got back from a fruitless quest to find brake grease. There is no such thing around here.
So now I'm wondering if there is anything else that I could use to grease the brake caliper slider pins besides something that is labeled brake grease or brake lubricant.
Needless to say, I'm looking for a substitute that is just as good (I wouldn't mind better).
A few other related questions if you guys don't mind:
1) What else do you lubricate when doing a brake job?
2) Are those little sachets of grease that come in the box with new brake pads, guide pins grease?
3) I heard of it being necessary to machine rotors when changing pads...but what about using old pads on machined rotors?
I have brake pads that have a lot of meat left in them and I was wondering if I could use them on machined rotors.
Thanks in advance guys!
'Are those little sachets of grease that come in the box with new brake pads, guide pins grease?' YES
I use Permatex anti-seize lubricant(the silvery messy stuff) on the guide/slider pins,on the stainless steel clips that the pads slide on,on the back of the pads(to prevent squeal). the clips and back of pads just require a slight film. I also use the stuff on my poly sway bar bushings,poly lca bushings,and poly panhard bushings. seems to last longer than regular grease.
most automotive stores carry brake grease.
http://shop.advanceautoparts.com/p/p...924%7CL2*15038
Slider pins I don't use anything but Permatex Ultra or specific brake lube
I used general purpose grease on mine once and it baked in there essentially freezing the pins in place
I'm also partial to Permatex
Permatex Extreme
I've gotten by in a pinch using antiseize in the past, but it tends to dry up quickly under abuse. I did have a seized pin once which required me to replace the caliper but I don't recall what I lubed the pin with that time.
I put the lube anywhere two separate metal pieces touch at mounting locations and may rub, including at the bottom and top of the pads where they sit in the mounting bracket.
Permatex Extreme
