which torque arm?
Old 07-20-2014, 11:51 AM
cchvyd28's Avatar
Default which torque arm?
Hi, i purchased a 9" for my 96 camaro. The stock torque arm cant be used with the brackets installed on the rear and I was wondering if anyone would know of a torque arm that would bolt right up to it. I did purchase the bracket from currie, but if there is a way that this can be more of just a bolt in and avoid welding i would prefer it. I know the pic is upside down so if anyone wants other pics i can take them. Thank you for your help.
P.S. This is not a rear purchased from any manufacturer someone had it made.
Old 07-20-2014, 12:15 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
We have one that will fit, should be a pretty easy bolt-in setup. Give us a call during normal hours and we can get you setup.
Old 07-20-2014, 12:39 PM
cchvyd28's Avatar
Ah ok i see which one you probably mean. Does that one need a new crossmember to mount to as well?
Old 07-20-2014, 03:52 PM
garygnu's Avatar
I would get a cross member that relocates the torque arm off of the tranny tail shaft .go to midwests website ,and see what they have .
Quick Reply: which torque arm?
