Driveshaft loop w/ tunnel brace torque arm?
Old 07-20-2014, 05:46 PM
Caribe's Avatar
Default Driveshaft loop w/ tunnel brace torque arm?
Has anyone added an aftermarket driveshaft loop to a tunnel mounted torque arm?
Old 07-20-2014, 06:10 PM
Undertow74's Avatar
Yes why not? You remove your floor pan brace and the loop bolts in place of that.
Old 07-20-2014, 06:22 PM
Caribe's Avatar
If your torque arm is already is tunnel braced your floor pan bolts are already used by that.
Old 07-20-2014, 08:24 PM
Undertow74's Avatar
MWC tunnel mount brace/loop combo
Old 07-20-2014, 09:55 PM
Caribe's Avatar
I guess I was looking more as an add on ds loopinstead of having to replace a current crossmember without torque arm.
Old 07-21-2014, 08:58 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
We do have a bolt-in driveshaft loop that should work with your current crossmember... it is a custom item that is form-fitting to the tunnel. Nothing hangs down at all.
Old 07-21-2014, 10:57 AM
BMR Tech2's Avatar
Ours is designed to add to our short style torque arm crossmember, but it can be easily modified to be added to any crossmember setup.
http://www.bmrsuspension.com/?page=p...250&superpro=0
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Quick Reply: Driveshaft loop w/ tunnel brace torque arm?
