Firehawk...lowered? How much?
Here goes....I figure that I might get bashed a bit on this one. My car has the Bilstein's and is definately lower than a "stock" T/A. I'm wondering if any Hawk owners DON'T like the car being lowered? Also, what would I need to do to get the car up a bit in the rear? What negative effects would this cause?
How much do you want to raise it? Maybe a set of adjustable spring perches from Ground Control would help, but they may make it too high. You could use them, remove the upper isolater and replace it with heater hose. That would probably get you exactly where you wanted.
By the way I had the Bilstein and thought the rear sat well, but the front was too high. I ended up lowering the front.
Not my car, but it :
