Help with trying to make car hook
I have a 02 T/A with a 9 inch rear, turbo 350 trans., 4/11 gears, M/T Pro radials, making 650 N/A and extra 200 NOS. Hooking this car is kinda hit and miss. I have all BMR adjustable, lower LCA's, Full length T/A with relocate bracket, strange single adjustable front and rear shocks, 12 positions. I have played with my shocks and cant get a consistent hook out of the car. Main question I have is, I have my instant center set at where my T/A front mount is located, if I adjust that more to the back of the car, would that give more bite off the line, car has been lowered also, rear LCA's are in bottom hole of relocate brackets and have probably 1" of kick up in the front.
LS1Tech Premium Sponsor
I would recommend running the front shocks a couple clicks from full loose and on the rear I would run them a couple clicks from full stiff. This will give you a decent baseline to start with the shocks. Where do you have your torque arm mounted on the relocation crossmember? This will determine what your instant center is. I would also think about moving the rear LCAs up one hole on the relocation brackets too since the car is making a good bit of power. There isn't any reason you shouldn't be able to make your car more consistent we just got make sure everything is where the car wants it.
Also when the car hooks do have problems with it doing wheelies? I am just asking because I work on a car here locally that is similar to your setup but make a little less power and liked to wheelie but we cured that with some Madman limiters.
Kyle
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I do not know the current angle of the actual torque arm, I can check tonight, but where the torque arm line and the LCA line intersect is at the mount on front of the torque arm, I have no way to adjust my LCA's anymore than what they are, the T/A is probably kicking downward in the front just below level. Currently after street racing this past weekend at my local track, only way I could run from unprepped end was to leave at idle, feather throttle and all shocks set to 0. Prepped end, I have hooked on an extremely prepped surface with 4 on rears and 2 on front N/A and 4 on front with 200 shot. I know I will never completely hook on street with this car but trying for optimal positioning.
The T/A is currently mounted in the second hole from the top, top holes are slotted and bottoms are staggered but I am in second set from top. I was told the LCA's need to have a upward kick in front, if I move them up one hole, the front will be pointing downward, is this correct. The car has never had a problem with wheelies.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Definitely play around with the car a little bit and see if you can get it to come out of the hole a bit softer and I have a feeling you will find much better consistency. Let us know how it works for you.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
I ordered a set of Hoosier slicks and will be putting them on tomorrow to run on the street end or unprepped end of our track, do you recommend same settings for the slicks? I am gonna continue to run my radials on prepped end.
I would stick with the same recommendation for the Hoosier slicks that we were talking about because they should still work well for you. You may be able to get a little more aggressive with the slicks compared to the radials but I would still start off pretty conservatively and adjust from there.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
