Cutting strano springs... stupid idea?
Like 90% of 98-02 Camaro's out there, mine sits uneven. I know it's a fact of life, but it drives me crazy.
To make a long story short, if I cut 1/4 coil off the driver side front coil to help level out the car, will it kill the performance of the springs? Or should I just leave it alone and take my OCD meds?
I don't want to screw anything up because it drives awesome right now.. but I would like to level out the ride..
Get some coilover sleeves to put on the shocks and then you can dial in the height exactly where you want it, and still retain the good shocks and springs that you already have.
Cutting the spring is a permanent mod, and there is no guarantee you will get the height you want either(may end up going too low), and then you are just stuck with a ruined spring.
Ground Control makes them. The link is int the first post. I won't repost it, as I don't think they are a vendor here.
https://ls1tech.com/forums/suspensio...ers-worth.html
I dont think they are a sponsor (so Im not going to risk posting a link) but ground control makes some coilover sleeves, you can find it with a google search.
https://ls1tech.com/forums/suspensio...-coilover.html
May want to double check with Sam that his springs will fit right with those.
I thought you weren't suppose to use the lower perch on the koni's..? How is using a coil over setup different than using the lower perch?
I was thinking that if I use the lower perch on the drivers side it might get me really close to where I want to be, but again, I don't want to mess anything up.
Pontiacerator
It would be unorthodox, but I can't see anything horrific happening by running one on the upper and one on the lower perch. It would make up for a .5 -.75 height difference. Any less than that would just bias it to the other side. I doubt there would be a noticeable handling problem as a result, although spring travel would differ from side to side.
It's free, it's easy to do, and if you don't like it, you can always switch back, no harm done.
I run the GC kit...it won't work with the front Strano springs. It's also a pain to install the sleeves over the front shocks (koni)...lots of grinding.
Once installed it is just ok (I'm being nice) for street if you want height adjustability...the GC kit does deliver that..again, not without its quirks..Tough to find an equivalent at that price point.
What are the drawbacks to the height adjustability?
LS1TECH Sponsor
As for cutting. You can do what you want, but don't use a torch. Wouldn't recommend it, and would tell you to paint the bare end if you do. But the cars sit left side high, that's how they are.
If the height is killing you that much, then feel free to cut them if you wish (again not recommending this) or look at something that allows height adjustment while retaining the high end damper.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1Tech Premium Sponsor
Just going to throw this out there, our SA001 spring seat adapters will make any stock style spring work on any 2.5" coil-over style shock setup
http://www.bmrsuspension.com/?page=p...294&superpro=0
