WTF??!? Brake piston won't compress!!
1 Post
Hey guys, I'm trying to replace the brake pads on my DD, I've gotten everything apart, I'm at the point where I need to reassemble everything - but the freakin' brake piston absolutely won't compress!!
I've tried using the normal tool that I always use (looks kind of like a metal brake pad with a bolt threaded through the center of it), I've tried using a BIG pair of channel-locks that I have, as well as my neighbor's welding pliers. I've applied enough pressure (using the pair of channel-locks) that it broke the handle on the brake spreader tool that I normally use. I've had my neighbor over here to lend a hand (he's a fireman who has forearms like Lee Haney) & he wasn't able to get it to budge either...
And yes, I do have the cap loosened on the master cylinder, but it's like there's a check valve or something that's holding the pressure in the line. I've tried releasing the bleeder valve, but that doesn't seem to help much... I've even called the service dept. at the dealership that's done a bit of the major work that's been needed, but all they told me was stuff that I already know.
Can anyone here offer any tips/suggestions?? It's starting to cloud up again, & I'm really hoping to get this done before the rain starts...
Thanks guys.
Thanks guys.
1 Post
And when I say "won't compress", I mean "WON'T compress"!
I decided to (carefully!) see if I could "step up my game" just a little so that I could get it compressed just enough to slip the caliper over the new pads. So, I grabbed an 8" c-clamp from the drawer & found a 3-foot bar that I've occasionally used as a "cheater bar". The first couple of revolutions went OK - I was going slowly, paying close attention to how it felt...
The last 180* produced this:
(As you can see, I didn't beat the rain...) That's where I've left it for right now - trying to swap these brake pads (on just ONE wheel!) has cost me two tools, & caused a bit of pain in the wrist that I had repaired earlier this year - not worth chancing another problem with that! I'm a bit disgusted at the moment. I guess the good thing is that I didn't hurt the car, & I don't think that I did any lasting damage to myself...
Just gotta figure out HOW in the hell to get that last 1/4" or so...
1 Post
Errrrr... (No one was supposed to ask that!)
It's a (reasonably) late-model Saab 9-3... But it has a LOT of GM parts, both under-the-hood, & in the rear suspension, where I'm working now...
1 Post
I've pretty much decided that tomorrow morning I'm going to just disconnect the hose from the caliper block, clamp the hose(s) shut, fit the caliper over the rotor & new pads tomorrow, & deal with bleeding the brakes. It's been down for long enough already.
1 Post
BTW - here are three pictures, I'm hoping they'll be helpful:
BIG THANKS guys, I really appreciate the suggestions!!
1 Post
Ahhhh, #%$@(%*... Thanks for letting me know, I'd never even heard of those before this weekend...
I'm guessing that the part that I circled in red is the tip-off that it's a twist-in caliper/piston??
1 Post
Well, it appears that I MAY have dodged a bullet (either that, or the fact that I've learned to go slowly/take it easy when I'm not sure about the work I'm doing helped...).
I'm fortunate (?) enough to have a HF location fairly close by, so I bought the tool kit, & WHADDYA KNOW?!?! It's just amazing how easy it is when you're performing the correct procedure!!
Took the car out to an empty road nearby & did a couple of hard stops from 40 mph, then another from 50 mph, & finally a couple of hard stops from 60 mph. All of them performed as expected, no pulling to one side, no unusual noises, etc. I'll pay a little closer attention to how it stops over the next couple of days, but my gut's telling me that it's OK.
THANKS AGAIN for the help guys. I was really wondering WTH was going on...
As an an FYI, I was able to complete a brake job on calipers like this with channel locks, a c clamp, and some patience. The tool is optional but definitely helpful.
1 Post
The way that I did it when I was testing to see if the piston would rotate was to cover the piston with a shop rag so that my channel locks didn't put any scratches on the piston, then try to grip the piston itself (and not any of the rubber boot that it was sitting in) with the pliers & see if I could turn it - which of course it did easily. HOWEVER, between the angle I had & the large pliers I was using, I could only get about 1/8 of a turn out of it.
And given the fact that I had to make five or six revolutions to get the piston seated, I'm thinking that the $40 that I paid for that tool set certainly wasn't wasted. The job went really quickly & easily once I had the correct tool & followed the correct process.
THANKS AGAIN to all who corrected my understanding. I truly appreciate it.
I had the same problem back in june. What i did was took a c clamp and forced it back and forth. Then pressed the brakes then repeat. After a bit i took a tire rod and a hammer and did the same eventually it worked just fine.
