4 channel/ 3 channel rear end
hello everyone so I had a 3 channel rear end off of my Camaro and a have a 4 channel rear end off of a 2002 Camaro ss my rear end is done so I was wondering if it will b compatible with my car I seen that my car only had one brake line port to plug into and the other rear end has 2.. is there anyway to make this work.
You'll need to swap your brake lines. Does it have the hole for the speed sensor drilled in the center section? If you want to keep the abs you'll need to install that sensor, pull the diff cover first and see if it has the abs reluctor next to the ring gear. If not, you'll need to add that as well.
Thank you
Should work okay, abs light will probably be on, maybe low trac light as well but, assuming the brake system is in good shape and bled well, the brakes should work fine. Just no abs operation.
