Anyone have a wiring diagram for the abs module?
I need a wiring diagram for the abs module on my 98 trans am. Mainly need to know which wire is for the malfunction light on the dash. Thanks
the abs light in the gauge cluster is set by a serial data command from the pcm to the gauge cluster. the gauge cluster is essentially a computer. there is no single wire going to the gauge cluster that powers that specific light, nor any other. you would need engine computer software such as hptuners or efilive which lets you reprogram your computer and would let you disable ABS.
Ok thank you for the input. Car I bought has a 9" installed and no abs on it so the light stays on. Guess I'll have that done when I get it tuned after I put the blower on
