Sway Bar End Links
Old 05-24-2004, 11:43 AM
ZigZagZ's Avatar
Default Sway Bar End Links
I just got my hands on a 1LE front sway bar. I was wondering if I should update the end links with polyurethane units.
Positives?
Negatives?
Comments?
Criticisms?
Thanks
Old 05-24-2004, 02:50 PM
NHRATA01's Avatar
Sure, I can't see a reason why not to do it. Cheap and easy mod, and stiffins things up a bit, seemed to slightly cut down on roll IMHO when I did them. Plus the polyurethane will last along time - I recently replaced the endlinks on my '89, and after 15 years the rubber bushings were all rotted out, and 3 out of 4 rusted to to point where they snapped.
Old 05-25-2004, 03:17 PM
4mula1's Avatar
Absolutely IMO, if you want to get the full advantage of that bar then I would.
Old 05-25-2004, 03:22 PM
Tranzor's Avatar
Yep, that's what I did... put some poly bushings in the rear too while you're at it. They're so cheap, there's no reason not to.
Old 05-25-2004, 03:42 PM
Cal
Cal's Avatar
Poly end links on the front or rear work great. Poly center bushings on the front work great. Poly center busings on the rear bar sound like a squeaky old screen door flapping in the wind! Might want to stick with the black rubber 1LE bushings on the center of the rear bar.
Old 05-26-2004, 01:02 AM
Tranzor's Avatar
Haven't had that problem with my rear sway bar endlinks... been in for over a year now and no problems so far. My stock endlinks on the other hand, squeaked like a ****.
Old 05-26-2004, 09:43 AM
ZigZagZ's Avatar
Thanks for the input. Poly end links have been ordered, and should go in this weekend.
Quick Reply: Sway Bar End Links
