BMR Suspension New Product-4-Point Subframe Connectors for 4th Gen F-body SFC019/020
Old 12-18-2014, 01:10 PM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
Talking BMR Suspension New Product-4-Point Subframe Connectors for 4th Gen F-body SFC019/020
BMR Suspension 4th Gen GM F-body Sub-frame Connectors
Reduce chassis flex and improve handling on your 4th Gen GM F-body with four-point sub-frame connectors from BMR Suspension. Since the F-body does not have a full frame, the chassis flexes dramatically even with mild amounts of torque and horsepower. Manufactured from a mix of 2- x 2-inch square tubing, 2- x 1-inch rectangular steel tubing, and laser-cut CNC-formed 3/16-inch steel plate, these sub-frame connectors add loads of strength in all the right places. The BMR Four-Point Sub-Frame Connectors (SFC019 weld-on, SFC020 bolt-on) connect the front sub-frame to the rear sub-frame to the rear lower control arm mounts to the transmission tunnel brace. This four-point design is far superior to other subframe connectors on the market, because it links the front and rear sub-frames, where others only connect the front sub-frame to the lower control arm mount. The BMR design does a much better job of preventing the rear of the chassis from flexing. BMR has designed the SFC019 and SFC020 for street performance, drag race, and handling applications. Available in black hammertone and red powdercoat for long-lasting good looks. Installation time is about 2-3 hours. Proudly made in the U.S.A.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
__________________
Allan Miller
President
BMR Suspension
(813) 986-9302
Quick Reply: BMR Suspension New Product-4-Point Subframe Connectors for 4th Gen F-body SFC019/020
