cars feelin a bit bouncy?
when i go ever small hills in the road the car comes down and has a bounce to it....my car is lowered and the shocks havent been changed yet?
should i look into changing them? open to suggestions
J
J
The stock front shocks are not valved for anything but OE springs. Call Sam @ Strano Performance and he can set you up with Bilsteins HDs that are re-valved specifically for whatever spring you are running. While you're at it, replace the rears with the Bilstein HDs as well.
Good luck!
Good luck!
Originally Posted by Fulton 1
Yup, in most all "bouncing" cases it means the system is underdamped and different shocks are needed for your particular spring.
will bilstein HD's be the right ones for me?
J
Are you talking about a 'bounce' similar to that from worn out shocks or the 'bounce' similar to the ricer bounce. I see the ricer bounce all the time around here when those imports are lowered. Not quite sure what causes them to bounce like a go cart but it does look funny.
example- if im on the freeway and cruzn along the car doesnt feel as solid. it has bounce when i hit grooves in the road. when it hits a bump it doent just hit but has a nice lil bounce to it after.
J
what does a worn shock feel like? maybe i am not explaining it right seein that im not positive what a worn shock feels like.....
J
J
You're using the Eibachs? I'd give LG or Sam Strano a call. They'll be able to recommend a set of shocks to go with your springs. Some properly matched shocks will go a long way toward solving your problem.
