Spohn Pro Rear Drag Sway Bar users, help needed!
I finally got my Spohn Pro drag bar I ordered from Custom Performance....5 weeks it took.
In the instructions, it says that the bolts that hold the rod ends together are pre-set as far as being against the spherical bushings. Mine were NOT pre-set. As a matter of fact, they were barely even on. I called Spohn 15 minutes after they closed.
How tight are they against the bushings? I just tightened them enough to get into the locking section of the nut. Definitely too loose.
Thanks!
Thanks!
