Caliper Bolts for 2004 CTS-V Brembo Front Calipers (Camaro Swap)
I'm doing a front calipers caliper swap on my 1999 Camaro, so I was looking for the correct bolts for the caliper I ordered some on ebay PN-5917 (H5095) However they're too small. Where can I get the proper calipers bolts or do the ones on my Camaro fit the Brembo calipers.
Caliper bolts
The factory bolts work just fine. That's whatr I used for my install. Other wise you can get Grade 8 bolts or cap screws at any local fastener supplier. Take the factory ones with you to make sure you get the right thread. If memory serves the are M13 metric.
caliper bolts
If your putting CTSV calipers on check this out.....
http://www.superchevy.com/how-to/bra...-tires-wheels/
CTSV 6 PISTON CALIPERS USE 14MM BOLTS
