Vibration after UMI Torque Arm relocation
Installed a UMI torque arm relocation crossmember over the weekend. The car had zerodriveline vibrations, and now vibrates like crazy around 70+ and does it even worse when i let off the gas pedal. It feels like pinion angle to me. I installed the tq arm into the second from bottom holes as described in the directions for the stock height tq arm mount, and am still using the stock torque arm with a stock rubber trans mount.
I am wondering if the new crossmember changed the mounting angle of the transmission? It seems like my only option is either, 1) buy an adjustable torque arm and start checking and adjusting angles, or 2) get rid of the UMI piece, go back to stock, and pray i don't break my tail shaft.
You have to remember you're removing one of the areas that compresses under acceleration/deceleration by relocating the torque arm nose. Basically, before relocation, any vibration may be controlled by the torque arm mount, trans mount, and motor mount. Now any vibrations essentially must be controlled by the torque arm mount.
The other thing is the pinion angle is intended to be in factory location at the second hole from the bottom. That's not to say every vehicle will react perfectly to that location. It definitely won't hurt to try some of the other holes to see if the issue is alleviated.
An adjustable arm is definitely one way to cure the problem, and can be beneficial in more ways than just being adjustable.
When I installed a UMI relo trans xmbr it lowered my trans .375 inch compared to the stock xmbr. I shimmed up the trans mount to correct this. At that time I had the stock TA and used the 2nd set of TA mount holes from the top as these seemed to position the TA closest to the stock mounting points on the trans tailshaft.
UMI summed it up best. You have essentially removed 2/3 of the items that originally absorbed a ton of vibrations. I agree that you should do your best to get pinion angle correct but I think even after you do you're going to still have vibrations coming up through the body. You don't have stock JUNK in there anymore bro.
Ive been dealing with this issue myself. I have a adjustable BMR torque arm and at 70+ it vibrates and at higher speeds letting off the accelerator it feels like its about to come apart. I got it up level with the rear susp loaded and car level and was told should be -2 to -3 degrees by BMR. She was at about -3 1/2 and just my luck every adjustable wrench I have I left at work. Im not a racer,, so if I cant get a handle on it Im going back to stock parts because the vibration makes the car not fun to drive and that sucks complete *****
high speed vibe
if you know your pinion angle is correct at -2° and it's still there.... buy summits DS $360... problem solved. I went 5 months battling same thing. 2 used driveshafts " balanced" with new ujoints and still no change. Apparently all of the gear and axle shops in DFW don't do high speed/high rpm balancing, bit the new DS from summit comes that way. 133 mph..let off and still no vibe! I can actually get full freeway potential out of my SS now!
